A/C delete
Old Nov 19, 2018 | 01:24 AM
dr.acula's Avatar
A/C delete
A/C delete means i have no capability's of getting defrost to work? all my vents blow strong but nothing hot enough to defrost or keep me warm haha
Old Nov 19, 2018 | 08:45 AM
Re: A/C delete
A/C delete has nothing to do with hot coolant flowing to the heater core, or determining which vents the hot air flows to.
The coolant always flows to the hearer core (unless the core is plugged with sludge), and the flapper door that switches between hot and cold air flow is cable operated by the temperature control ****.
Old Nov 19, 2018 | 04:28 PM
dr.acula's Avatar
Re: A/C delete
so i can possibly fix this with taking the dash apart and opening flapper door and set my cable for the control ****? Only question i have is where the flapper os located. I dont wanna rip this apart more then i jave to if the flapper is under the hood somewhere. And ty man
Old Nov 19, 2018 | 05:19 PM
Re: A/C delete
You have to add a "SIGNATURE" so people know what year your car is, and other important info. Not all years are the same. I remember because I already asked you for the year in another thread. But others may not know, so they cannot provide help.
https://www.camaroz28.com/forums/lt1...nature-879835/
FIRST - if you don't have heat under any circumstance... heat or defrost... make sure the heater core isn't plugged up - a common problem. With the engine hot, both the heater supply and return lines should be very hot. If the return is not hot and the supply is only lukewarm, the core is plugged. There is no shutoff valve so the only other possibility is a plugged restriction orifice up by the water pump.
If the core is plugged up, pull both hoses off the water pump and flush with a garden hose. Do not get the distributor wet.
Restriction orifice (flow control valve) location - part #13.
Courtesy of Shoebox
http://shbox.com/1/heater_hoses.jpg
Here's a simplified diagram of the heat/AC controls. #6 is the temperature control flapper door:
Courtesy of Shoebox
http://shbox.com/1/hvac_vacuum.jpg
As far as the details of accessing it and repairing it, if that is the problem, unless someone else here has done it, you will need the factory service manual.
Free download of 1995 factory manual:
Courtesy of GaryDoug
http://www.mediafire.com/?40mfgeoe4ctti
Z28-50
Aug 26, 2011 07:17 AM
Camaro350z28
Mar 6, 2011 04:22 PM
rangers458
Dec 31, 2009 09:22 AM
My94M6
Dec 13, 2007 10:02 AM
Koby
Jan 31, 2007 03:09 PM
