breather question
Old Apr 16, 2009 | 11:06 AM
blackbirdta's Avatar
breather question
I did a search and I see that the stock PCV system is preferred over breathers. The engine I am talking about is in my '35 Ford and I can't deal with the hose running from the passenger valve cover to the throttle body...with after market polished valve covers it will be an eye sore.
Is my only option to remove that hose, cap the TB and use a breather leaving the rest of the PCV system intact? Will I need to add a second breather on the driver's side valve cover or is one enough??
Thanks!
Old Apr 17, 2009 | 02:05 AM
silentsprintero's Avatar
You could build a stainless hose/AN fitting line, that would look 100% better than stock.
Barb fitting to AN hose adapter-->AN 90*, stainless hose, AN 90*, and an AN to hose fitting with a short run of rubber to connect to TB. Or if you don't have the provision for a hole you can have someone TIG AN fittings to the VC's.
Old Apr 17, 2009 | 02:06 AM
Repost
Old Apr 17, 2009 | 07:35 AM
That sounds like an option if I must do it that way, but I still don't think that would look as good as a breather and making stainless lines is not cheap...I spent over $100 making up a line to connect the clutch...
Am I sacraficing too much by using breathers and should just suck it up and run the line?
Old Apr 18, 2009 | 10:08 AM
While it is best to keep the stock PCV system intact, removing the vent line from the throttle body, and replacing it with a breather is no big deal. It means a little bit of air is bypassing the MAF and getting into the combustion process, forcing the long term fuel corrections to compensate. But its nothing major. I've been considering going to a breather, but I don't use an MAF, running speed-density on an aftermarket ECU.
On the other hand, you may find that you have an oily film around the breather, that might be more unsightly than the hose.
Old Apr 20, 2009 | 10:37 AM
Thanks Injuneer..I think I'll give the breather a try and see if I get any oily film problems.
Do I just need the one breather on the passenger side?
Old Apr 20, 2009 | 06:55 PM
The stock system only admits clean, filtered air to the passenger side valve cover, so one breather should be adequate.
HectorM52
Jan 30, 2015 11:34 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
High HP TA
Sep 6, 2002 08:00 PM
