Bleeding brakes with vacuum pump?
Old Nov 15, 2004 | 08:59 PM
Camarocks's Avatar
I picked up a vacuum pump from Auto Zone tonight, the one that runs around $25. It says on the package that it can be used as a one-man brake bleeder as well. Is it a good idea to bleed brakes this way? Does it do just as good a job as having an assistant pump the pedal?
Old Nov 15, 2004 | 09:45 PM
Joe Bellman's Avatar
Re: Bleeding brakes with vacuum pump?
It does just as good of a job but with the vacuum you can do it by yourself much easier. This tool is a must for bleeding the brakes on the motorcycle.
I also use this tool to suck out all my ATF before changing the filter. It doesn't get so messy that way. Speaking of that, I usually suck out the ATF every 10K miles and then change the filter/ATF at 30k. 110,000 miles on abused tranny and still running strong
Old Nov 15, 2004 | 10:10 PM
Camarocks's Avatar
Joe, do you just hook up the vacuum pump to the dipstick tube where you add the trans fluid? I haven't even taken this thing out of the package yet. How much of the trans fluid are you able to get out that way?
Old Nov 16, 2004 | 08:34 AM
I connected a piece of hose (spare stuff from the fish tank) to the input of the collection cup. You will need about 7-8 feet of hose to make it easier. Anyway, I run the hose down the dipstick pipe until it can't go any farther, then I start pumping the handle. The vacuum pump will suck up the fluid into the cup.
Drawbacks: Takes about 15 min to suck out all the fluid because you have to stop and dump that cup after 4 ounces or so have been sucked out. You will end up filling the cup 30+ times since you can suck around a gallon of ATF out. Your hand/forearm will get a little sore from squeezing that handle.
A larger diameter hose would probably make things go faster. Next time I do mine, I will be using larger hose since the dogs chewed up my fish tank air hose
Magenta_Hearts
Mar 29, 2017 08:54 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
PurpleHaze95
Aug 21, 2002 07:56 AM
