BATERRY CORROSION!???? Can it?
Old May 5, 2008 | 03:50 PM
SATANAZ666's Avatar
Smile BATERRY CORROSION!???? Can it?
Ok so this morning I drove to my a friends house went in and came out in about 30 minutes and turn the key and all I heard was a clunk! It was coming from the starter area!
All lights accesories worket etc...It just wouldnt crank
I assumed it was the starter!
Well I go ahead and swap batteries just to see if for some odd reason it was the batterie..and wham it turns on!
I did notice some corrosion on both posts when I swapped batteries.
COuld it just have been the corrosion?????
This is about my truck a 98 Chevy subuBurban LTZ
Old May 5, 2008 | 04:11 PM
2000GTP's Avatar
Possible that a loose/dirty connection caused the problem. Have the old battery load tested and you will know the answer for sure.
Old May 5, 2008 | 04:27 PM
SATANAZ666's Avatar
Old Abttery
Actually the battery I took out from my car I put into the other car
and the OTHER car started no problem with MY batterie!
all I did other than the swap was clean off all this white stuff from the baterry terminatls.
Old May 5, 2008 | 04:53 PM
Yes, just corrosion can cause that problem. The corrosion provides enough resistance to block the flow of large amounts of current. Lights and stuff don't draw much of a load, compared to the several hundred amps that the starter draws.
Old May 5, 2008 | 06:45 PM
Chevycobb's Avatar
pour some coke on it and go
Old May 5, 2008 | 06:48 PM
caldercay's Avatar
I had a situation where the Z wouldnt shift out of first gear and the
car ran like cr@p. A mechanic suggested I clean the battery terminals.
I removed them, cleaned them thoroughly, and tightened them back up.
The problems magically went away.
Old May 5, 2008 | 07:13 PM
"The pause that refreshes".
An easy way to tell when you have a poor connection like that is to open the hood and have someone else turn the key. You will often hear a little pop (arc) and see a poof of smoke at the poor connection. That tells you right where it is.
drt
Sep 27, 2015 04:39 PM
Ryan's LT1
Jul 23, 2004 07:29 PM
DRIVEFASTKEEPLEFT
Apr 26, 2004 08:26 PM
Shawn 97 Z28 M6
Dec 18, 2003 02:58 PM
