Opti Harness Corrosion?!
Old Dec 17, 2003 | 11:17 PM
Shawn 97 Z28 M6's Avatar
Texas Moderator (1998-2009)
I just got done pulling off my 3rd opti of the year... And to when I pulled the opti harness, the connector assembly was all full of this blue powdery soot. Almost like that corrosion that happens to a penny after it's been sitting in water? Anyway.. This opti harness has maybe 2 months of use on it ~ as I replaced it two months ago w/ another opti in october, and I've never seen one look so crappy after such a short period of time. Even the brass vacuum end had some corrosion going on. Does anyone know how this can be stopped??
Would some electrical contact cleaner work okay to clean up the plug? Then some dialectric grease to kinda coat the pins on the replacement opti? Just lookng for some ideas on how to get some longevity out of this next opti.
Old Dec 17, 2003 | 11:40 PM
93formula's Avatar
the dialectic grease will deffinatley help from corosion. you can try to clean it up and reuse it, hopefully it wont give you any problems with ignition.
Old Dec 18, 2003 | 06:45 AM
I hope so.. these little puppies are pretty pricey otherwise!
Old Dec 18, 2003 | 06:57 AM
94 NO TOP Z's Avatar
I noticed that on all of my optis. I went thru 3 optis in 5000 miles... none ever exposed to water and never driven in the rain and they all had the "blue/green powder" in the connector.
Old Dec 18, 2003 | 07:21 AM
ksmyss's Avatar
3 optis in a year i dont understand how they arent lasting. i still am running the stock opti and it has 85,000 and i have also washed the motor really good atleast 4-5 times a year and have never even protected the opti once.
Old Dec 18, 2003 | 02:58 PM
LT1TONY's Avatar
I had the same problem with the corrosion. I thought my opti was bad replaced it and it still acted up. I thorougly inspected the harness and ended up replacing it. The damn harness was the problem. Car ran great after I replaced it. Do what 93 Formula said, use dialectric grease. That is what I used and put on and have had no problems.
jwade88
Jun 14, 2015 09:38 PM
Navecm
Jun 1, 2015 05:57 PM
zxtce
May 7, 2015 08:53 PM
ad356
Apr 22, 2015 08:35 PM
