Bad Opti?
Old Mar 21, 2019 | 12:47 PM
Logan Jones's Avatar
Bad Opti?
I bought a 93 z28 not that long ago and I think I need a new opti. The car will hesitate occasionally and happens all the time at higher speeds. The car also vibrates at idle and virbrates stronger during acceleration. I just wanted to get a second opinion before I drop the money on a new opti, wires, plugs and water pump.
Old Mar 21, 2019 | 08:14 PM
Re: Bad Opti?
Have you scanned it for codes? There are trouble codes that set for problems with the optical cam position sensor in the Opti (DTC 16 and 36). Easy to scan a 93 with a paper clip.
http://shbox.com/1/dlc2.jpg
Have you checked the fuel pressure, with the engine under full load, at 5,000+ RPM.
Have you inspected the spark plug wires, and the areas around the coil and the Opti for arcing? Are the plug end connectors snapped on tight? Are there any signs of corrosion buildup on the wire terminals on the Opti cap? Is the water pump weep hole dripping on the Opti?
Have you inspected the spark plugs for excessive gap/eroded electrodes, heavy carbon buildup, and cracked insulators?
Have you had the ICM tested by a shop, making sure they get it good and hot while testing?
How old are the O2 sensors? How many miles on the engine?
Has the engine been modified in any way, e.g. - headers, cam, etc.?
Old Mar 21, 2019 | 08:20 PM
Re: Bad Opti?
And while we're at it, did you resolve the “bang when starting” issue? You never followed up on this thread:
https://www.camaroz28.com/forums/lt1...arting-887284/
Old Mar 22, 2019 | 12:09 PM
Re: Bad Opti?
I had one of my friends who’s a mechanic listen to it and he said it was something with the starter shims.
IPrice
Dec 18, 2008 09:11 PM
hotheadbuddy
Mar 24, 2008 01:10 PM
drptop70ss
Jul 15, 2007 11:05 AM
Punkillr
Jun 8, 2004 04:16 PM
IDriveAZ28
Nov 9, 2003 05:41 PM
