no spark
Old Mar 14, 2008 | 08:05 PM
hotheadbuddy's Avatar
no spark
my car died out and after checking for spark i found that i have spark comming fgrom the coil two the opti but no spark comming out of the opti to the plugs this is my first issue with this type of disttributer please tell me if this is the opti or could it be something else thank you very much for your help
Old Mar 14, 2008 | 08:13 PM
mean96z28's Avatar
What year is your vehicle?
If it's a 93-97 then it's more than likely the opti-spark.
The opti-spark is always a problem with these cars because not only is it underneath the water pump, but it's a little behind it as well so even the slightest drop of water could kill it. Another thing that could go cause it to go bad is high reving.
Another thing might be your cap and rotor which are part of the opti as well (sort of).
I just replaced my opti roughly about two months ago and I can tell you this... They say it's suppose to be a 6 hour project, well I did mine in 2 (Ha).
If you want step by step instruction then I'll type them up for you, it's just a matter of if you have another opti lying around or not.
I, myself, have two brand new distributors because well.... You never know when it'll go out
Old Mar 14, 2008 | 09:07 PM
LT1BanditTA95's Avatar
Had exact same problem a year or so ago... spark from the coil..and then thats where she stopped... replaced opti and that did the trick... yeah your goin to have fun on this if your on your back...I no I did .
Old Mar 14, 2008 | 10:31 PM
Spark going into the opti and not coming out is probably a rotor failure.
Old Mar 24, 2008 | 11:38 AM
i got the opti off and the rotor was in a million pecies. i put a rotor from a 94 on it and it missed at low rpm. the cap and rotor were new from gm but no longer under warranty. is there any place that sells just a rotor. thanks for your replys.
Old Mar 24, 2008 | 01:10 PM
ss.slp.ls1's Avatar
If your rotor disintegrated, who knows if it caused any damage to the rest of your opti. I would suggest you replace the whole thing, other than just getting a new cap and rotor.
Formula Steve
Sep 19, 2023 08:31 AM
Jeff1904
Jun 5, 2016 05:00 PM
94Maroz28
Oct 27, 2015 04:38 PM
WobblySausage
Oct 7, 2015 02:44 PM
SEOJustin
Sep 24, 2015 04:39 PM
