Automatic Shift Knob Removal
Automatic Shift **** Removal
Does anybody know if it's possible to remove the factory Automatic Shifter. I hate the top style **** and I'd really like to change the handle to a B&M. Any feedback?
If you just want to remove the **** there's a 'staple' ('U' shaped pin) near the bottom of the **** on the front side that you have to pull out (small flat screwdriver or similar) before you can remove the **** from the stick
Also its easier if you turn the key to the on position and then pull the shifter all the way back into 1st gear, that way you can get to the staple. Then use a flat head screw driver or needle nose plyers, to pull the staple out, then just pull the **** striaght up, just be carefully if its the first time the **** has been off, because it will tend to stick then fly up and hit you in the chin(I found this out the hard way)
Originally Posted by Bud M
Just a plain 3d arrow with stripes on the end? Couldn't you make it animated or something?
I'll have to wait until donations at my site go up enough to support the extra bandwidth charges.
redz_02
Jul 24, 2002 09:42 AM
