ARP bolt kits
Old Feb 16, 2007 | 03:36 PM
r.serio's Avatar
ARP bolt kits
Do any of the vendors or any speed store for that matter sell ARP bolts as a whole kit for the LT1? I'm talking about every bolt, in & out. Ordering bolts for a complete rebuild would seem like a pita to me.
TIA
Old Feb 16, 2007 | 03:55 PM
rskrause's Avatar
Moderator
I can't see replacing things like valve cover bolts, header bolts, etc. Just MHO. I don't think there is an LT1 specific kit in any case.
Rich
Old Feb 16, 2007 | 07:14 PM
seawolf06's Avatar
Thunder Racing carries plenty of them. There is one set on there, not sure if it's what you're looking for or not.
Old Feb 16, 2007 | 07:18 PM
2000GTP's Avatar
I don't know if they sell one complete kit, as mentioned above Thunder Racing carries a kit that supplies fasteners for the following:
Intake Manifold bolts
Valve Cover bolts
Thermostat Housing bolts
Alternator Bracket bolts
Distributor Bracket bolts
Motor Mount bolts
Oil Pan bolts
Coil Bracket bolts
Header bolts
Front Cover bolts
Water Pump bolts
Fuel Pump bolts
http://www.thunderracing.com/catalog...vid=4&pcid=157
That doesn't include the bolts for the heads, connecting rods, main caps, ect. Once you factor those in, it will be a pretty costly upgrade.
Old Feb 16, 2007 | 07:19 PM
seawolf06's Avatar
You definitely don't need to worry about the coil bracket bolts, for instance. That's why no one buys these as a kit. Just buy them as you need them.
Old Feb 17, 2007 | 05:37 AM
r.serio's Avatar
The short block & heads get the new bolts. Thanks for the replys.
Old Feb 17, 2007 | 07:40 AM
wrd1972's Avatar
Thats what I am doing too, everything else seems like a waste.
Old Feb 17, 2007 | 06:55 PM
seawolf06's Avatar
Same here. I got them for the headers, too.
DirtyDaveW
Mar 15, 2015 07:01 PM
cyteone
Feb 7, 2015 06:04 PM
blac94Z
Jan 22, 2015 11:19 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
