1995 TA-how much does it weigh?
Old Feb 17, 2007 | 08:17 PM
maro z28's Avatar
In the door jam it says 4268lbs. The guy at SJM said its more like 3700lbs. Which is it?
Old Feb 17, 2007 | 08:21 PM
The sticker on the door is maximum weight-fully loaded with passengers and cargo.
Old Feb 17, 2007 | 08:30 PM
maro z28's Avatar
How much weight is added for people and cargo? I.E How much does the car alone(stock) weigh?
Old Feb 17, 2007 | 09:47 PM
LiENUS's Avatar
Shoebox was a little vague in what he said, I believe he means to say it is the maximum weight your car + passengers + cargo can weigh and still be supported by the stock suspension (iirc that is..) your car weight varies by what options you have, the best thing to do is goto an interstate weigh station if you want to know your weight (do they still weigh passengers cars?). If you want to come up to baton rouge I could possibly get someone to properly scale your car (tell you the weight on each tire individually) for a modest fee... (to him, not me)
Old Feb 17, 2007 | 09:49 PM
Not on "LT1/LT4 Engine Tech.
Moving................
Old Feb 17, 2007 | 10:21 PM
maro z28's Avatar
Will do, maybe not for a while though. When I get my new wheels/tires, rear end and cam, I'm going to a track in BR. They'll probably have scales there. Thanks!
Old Feb 17, 2007 | 10:50 PM
scott9050's Avatar
You can get a weight at most tracks or at quite a few interstate truck stops.
Old Feb 17, 2007 | 10:56 PM
LiENUS's Avatar
Do racetracks individually scale each wheel or do they only give total?
Old Feb 17, 2007 | 11:17 PM
camarolvr69's Avatar
you subtract 721 lbs from the "max loaded" number...its all on door panel, theres a sticker that has weight distribution with total gvwr, and another sticker that has the weight for passengers and cargo.
Old Feb 17, 2007 | 11:23 PM
maro z28's Avatar
Thank you...that's what I wanted.
Parts Wanted
May 1, 2016 10:25 AM
cocopops
Cars Wanted
Feb 1, 2016 06:22 PM
Ericksd
Jan 20, 2016 06:07 PM
KYWes
Sep 26, 2015 08:49 AM
autoxr166
Sep 25, 2015 04:21 PM
