Arm Rest/Door Pull Removal
Old Aug 24, 2004 | 12:35 PM
JoeMack's Avatar
Does anyone know how the arm rest is attached to the door panel on an 02 Z28? I was planing on replacing it but while I was looking at the door panel on my sons 99 Camaro, it looked like there was some sort of plastic rivet holding it on (besides the srews). I did not want to remove the door panel until I was sure that the arm rest is a seperate part from the door panel.Thanks for any help.
Old Aug 24, 2004 | 01:17 PM
97LT1F-Body's Avatar
Re: Arm Rest/Door Pull Removal
Your door panel should be the same as mine, I have a 97 Z-28. I just recently took off the door panel. It had two screws to be removed that are visible on top of the arm rest and two in front that is near the power controls for mirror, door locks, etc. Dont forget the one screw by itself that is directly above the handle. All together there was 5 screws. I also suggest you take off the little triangular plastic piece on the inside of the mirror. It helps when you are aligning the panel to put back on.
Mike
Old Aug 24, 2004 | 03:18 PM
JoeMack's Avatar
Does the arm rest seperate from the door panel that way?
Old Aug 24, 2004 | 11:27 PM
TraceZ's Avatar
No. It is all 1 piece.
Old Aug 25, 2004 | 03:22 PM
JoeMack's Avatar
Can the arm rest be seperated from the door panel? If so, how is it done?
Old Aug 26, 2004 | 08:44 PM
JoeMack's Avatar
ttt
Old Aug 27, 2004 | 01:09 PM
Z28SORR's Avatar
Once you have the screws out You have to push in at the top along the window seal and lift the whole panel up/out. Look at the back side of the panel, I beleave the arm rest just snaps in place.
Old Aug 31, 2004 | 12:08 PM
JoeMack's Avatar
Anyone else with experience in removing the arm rest/door pull from the door panel?
Victor Lamb
Aug 26, 2017 02:52 PM
canbaufo
May 5, 2015 03:43 PM
BigWil
Mar 29, 2015 12:24 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
