Anything to take note on removing the headliner?
-pull the a-pillars
-Pull the dome light
-What about the rear panels do I loosent them or anything?
I assume best way is out the hatch?
Re: Anything to take note on removing the headliner?
Best way is out the hatch. You also have to remove the coat hangers from the trim in the back because the headliner is behind them a little. There's also a platic pin that holds it up in the back that I believe you see when you take the dome light out. You have to seperate the plastic trim where the seatbelt meets the headliner too. Fortunately the headliner is slit so that the seatbelts slide through.
Yeah, actually I went out after posting this, looked up and said to myself "Damn, forgot to mention the sunvisors" But I figured you'd know that part. Bonus when taking your headliner down, you get to see a tag listing when the roof was put on and what shift did it, at least mine had that tag.
Victor Lamb
Aug 26, 2017 02:52 PM
NewsBot
May 16, 2015 05:20 PM
Apr 16, 2015 09:57 AM
