another problem 94 camaro overheating?
Old Mar 31, 2015 | 06:21 PM
  #16
Re: another problem 94 camaro overheating?
I'm not aware of a third bleeder.
At any time have you flushed the coolong system? Have you checked for leaves or foreign matter blocking the front of the radiator? Have you checked the seals surrounding the radiator to insure air is not sneaking around the sides? Have you cheched for a soft or collapsing hose on the suction side of the pump?
Old Mar 31, 2015 | 06:24 PM
  #17
grabbem88's Avatar
Heater core "T" thermostat housing and throttle body
I did coolant mod so I don't use that anymore
Old Mar 31, 2015 | 06:28 PM
  #18
grabbem88's Avatar
Lol well this 93 does or did have
Old Mar 31, 2015 | 07:34 PM
  #19
warmeck's Avatar
the dealer flushed/filled the cooling system about 4weeks ago, i do see a couples leaves and a couple pine leafs on the radiator. all the sealers are air tight testing the radiator for pressure; the only soft hose that i can pull around is the hose coming from the radiator to the reservoir?
Old Apr 16, 2015 | 05:50 PM
  #20
warmeck's Avatar
turned out to be a bad radiator.
liamcg97
Nov 25, 2019 05:55 PM
Red Hawk 94
Mar 18, 2019 04:03 PM
bernie1951
Dec 10, 2014 10:03 AM
siguy
Nov 27, 2014 10:07 AM
Chrisdude
Jul 24, 2002 02:25 PM
