Aluminized steel questions
How durable is aluminzed steel? I am about to put alot of money into my aluminized duals to have them run over the axle and i need to know how long the aluminized piping will last? I drive my car in the winter so its subject to the road salt
Does anyone know how long it takes to rust, or if it ever does?
Does anyone know how long it takes to rust, or if it ever does?Thanks
Re: Aluminized steel questions
The exhaust piping may be immune on the outside with the coating, but it can still rot away on the inside from the moisture in the exhaust. Stainless steel is the way to go but it will cost more.
Most problems with exhaust system rust is from the inside out. Aluminized steel is just a marketing ploy. You want rust resistence stainless steel for longer life exhaust system.
Aluminized steel is simply mild steel with a very thin coating to act as a sacrificial anode. It will rust away, just not quite as fast as plain mild steel. Aluminized steel will last 18 months to three years in severe conditions, depending on metal thickness. If you drive in salt and you do lots of short trips (which allows moisture to remain in low spots), expect a short life from your components. If your system gets hot and stays hot long enough that there is little condensate forming it will last longer.
Red_94Formula
Mar 7, 2015 09:21 AM
Trevor98ramair
Jul 31, 2002 02:43 PM
