Alignment questions
Old Sep 20, 2004 | 09:29 AM
mmannSS's Avatar
Alignment questions
I need to get an alignment. I called the shop I normally take the car to and they said that it would need a 4 wheel alignment and that it would take three to 4 hours. Is this correct? seeing as how they charge $54 dollars (most cars) i think its a load.
Old Sep 20, 2004 | 11:38 AM
Z28SORR's Avatar
Re: Alignment questions
This is just a normal alignment by todays standards. It just means they align the front wheels to the rear track rather than independently. They don't usually adjust anything on the rear.
Old Sep 20, 2004 | 11:45 AM
Thump911's Avatar
I agree! I had an alignment done on mine after lowering and they can only align the front. They just check for toe +/-, camber +/- etc. It was about $65 CDN and it maybe took an hour!!
Old Sep 20, 2004 | 12:43 PM
Do they know the car is not front wheel drive?
A shop will usually measure 4 wheel alignment, but they only adjust the front, as Z28SORR said.
Old Sep 20, 2004 | 02:27 PM
n2ceptor's Avatar
Probably talking about a 4 wheel thrust alignment....
Old Sep 20, 2004 | 02:52 PM
1991l98g92's Avatar
It could mean that with their work load, the car wouldn't be done for 4 hours.
Get a $ estimate. Check around.
Old Sep 20, 2004 | 05:10 PM
Compstall's Avatar
Yeah, ask 'em about that '4-wheel' alignment on F-bodies and see what they say....
Old Sep 21, 2004 | 12:29 AM
lillbush5555's Avatar
I used to do alignments (before knee surgury) You CANT do a 4 wheel on our cars due to the solid axle. The ONLY way you could do it is if you had a adj panhard bar. The way they do it is set 1 sensor per wheel. They they do what is called a a center THRUST line alignment. which means there is a ima. line drawn through the middle of the car and they adjust the wheels to that. But 3-4 hours I used to turn them out about 2 per hour dep on how bad it was off. But $54 sounds pretty res. Think thats what the shop I worked at charged
Matt
Old Sep 21, 2004 | 08:42 AM
mmannSS's Avatar
That was basically it. The guy I talked to just didn't communicate that very well (or at all). I had to drop it off at noon and they couldn't get to it till the end of the day. The actual alignment only took around 30 minutes. And the only charged for the two wheel alignment like they were supposed to. I think the guy on the phone was calling the thrust alignment a four wheel alignment. At any rate they did a great job. Only cost $34.
oldschool
Feb 9, 2016 09:21 PM
dfarr67
Apr 10, 2015 07:44 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Noenav
Dec 6, 2014 07:35 PM
