AC Problems ?
Old Apr 13, 2005 | 07:20 PM
tbird's Avatar
AC Problems ?
When AC or defroster is turned on there is a loud sqeal ( sounds like a cat ) Does this mean that the compressor is bad or the belt is loose ? sounds fine when AC is not on...thanks
Old Apr 13, 2005 | 07:32 PM
myslowcamaro's Avatar
Re: AC Problems ?
have someone check the compressor clutch assembly. having mine replaced now. had the belt off of it since fall. sometimes it works backward where it will make a noise until you turn the defroster/ac on. good luck.
Old Apr 13, 2005 | 07:40 PM
tbird's Avatar
Re: AC Problems ?
thanks... what do u mean it runs backwards ?
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
