AC problem - what do you think this is?
Old Jul 26, 2005 | 12:42 PM
Scream And Fly's Avatar
Okay guys, here's the problem.
Today I went to use my car (first time in a week or so) and it's HOT out. Anyway, the AC started working fine, then start blowing warm air after 5 minutes. So, I end up going to the post office - car sat maybe 5 minutes. Start it up again, same thing. Cold air for 5 minutes, then hot. Finally, I make one more stop and it does the same thing. When I got home, I can see the compressor is not turning.
Any idea what this is? Could it just be that I need a recharge?
Old Jul 26, 2005 | 07:49 PM
HBHRacing's Avatar
Re: AC problem - what do you think this is?
No way to know untill the pressures are checked.
Old Jul 26, 2005 | 08:06 PM
slowpoke96z28's Avatar
maybe a freezing evaporator.
Old Jul 27, 2005 | 11:37 PM
NovaTodd's Avatar
If the ac gets cold, yo have plenty of freon in the system. I would check the drain on the evaporator box - a quick check would be to run the ac at idle and see if you have a puddle of water under the car. If not, you need to clear the drain (don't ask how I know!) - a piece of wire or 1/4" wood dowel will clear the drain unless there are large pieces of junk blocking the drain.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
