ABS questions. 93-97
Old Jan 29, 2019 | 04:15 PM
ESPCamaro74's Avatar
How many teeth on the reluctor wheel in the rear diff?
how many teeth on the reluctors in the hubs?
Is the 93-97 ABS system a “stand alone” system?
I want to retrofit this system to a pro touring type project
Old Jan 29, 2019 | 08:16 PM
Re: ABS questions. 93-97
The ABS (only) system (93-97) uses only the large reluctor gear pressed onto the differential carrier. The system is controlled by the electronic braking control module (EBCM). Don't know the tooth count, but I'll look at one of the 93-97 factory service manual to see if there is any info.
Tractional control was an option starting in 1995 (ABS + TCS). That system uses only the smaller reluctor gears, behind the hub on each rear axle. I have seen a reference on another site indicating the axle reluctors have 53 teeth, but I have no backup on that. This system is controlled by the EBTCM.
1995 ABS system schematic, courtesy of Shoebox:
http://shbox.com/1/ABS_schematic.jpg
Download(free) of factory service manuals, courtesy of GaryDoug:
https://www.mediafire.com/?40mfgeoe4ctti
Old Jan 30, 2019 | 07:47 AM
FirstYrLS1Z's Avatar
106 teeth on the carrier reluctor, 47 teeth on the axle reluctors.
Old Jan 30, 2019 | 08:12 AM
The source I read indicated 53 teeth for 95-97, 47 teeth for 98-02. And the diameter of the rings are slightly different. Is that info incorrect?
I'll see ifI can find that source again.
Old Jan 30, 2019 | 08:41 AM
The pic is for the LS1s' 98-02. The carrier reluctor ring part number goes back to the 93 model years,so 93-02.
The axle rings could very well be different for 95-97. GM doesn't list a part number for axle reluctor rings as it's part of the axle assembly part number.
Axle assembly part numbers. 98-02 LS1 26059972, 98-02 V6 26059962, 95-97 ( doesn't stipulate V6 or V8) 26063144.
I work on / rebuild the 98-02 rear ends and record information. The only pre-98 rear I've torn apart was a 95 V6 open rear end that had the carrier reluctor.
Old Jan 30, 2019 | 08:57 AM
https://www.ebay.com/itm/95-97-Camaro-Z28-Firebird-Trans-Am-ABS-Traction-Control-Axle-Reluctor-Ring-Wheel-/163278271804?vxp=mtr&hash=item260424b53c
Found
this on Ebay, 53 teeth.
Old Jan 30, 2019 | 05:07 PM
The 1995 factory service manual confirms the 106-tooth count for the carrier ring. The entire section on ABS does not indicate any differences between the V6 and V8 systems. The section on ABS + TCS does not state the axle ring tooth count.
Old Mar 27, 2020 | 05:46 PM
PSG's Avatar
PSG
Are the axel reluctor rings shown above for the four channel rear or are they the front reluctor rings?
Im trying to figure out the size (diameter) and tooth count of the front tone rings for my stand alone system.
Old Mar 27, 2020 | 05:56 PM
They are for the rear axles with TCS (4-channel). The front rings are integral with the spindle/wheel bearing/sensor cartridge, and as far as I am aware, are not separately replaceable.
Old Mar 27, 2020 | 06:00 PM
PSG's Avatar
PSG
Thank you.
Im not trying to replace the front rings. Im looking for the specs so I can read them with my aftermarket ecu.
Number of teeth and Diameter needed to read them accurately.
Old Mar 27, 2020 | 08:56 PM
Try the factory service manual. That's where I found the spec for the 3-channel rear ring.
You haven’t provided any info about your car, like the year, but I posted a link to a free FSM download in post #2.
Old Jun 10, 2020 | 09:36 PM
Zeetwentyfate's Avatar
Originally Posted by PSG
Thank you.
47 teeth is the number. 93-02 are all the same, i just busted 2 apart a few months ago to figure this out for myself.
just for anyone else wondering/google searching, the 4th gen Fbody front wheel hubs use a 47 tooth reluctor
JC89CamroKid
Jul 19, 2013 11:44 AM
twistedbowtie
Sep 10, 2011 08:27 AM
Mikes 1994 z28
Nov 27, 2006 11:16 PM
4SFEDZ
Jul 11, 2005 10:24 PM
Rich_z28
Apr 10, 2004 09:04 AM
