ABS/ASR Problem!!
Old Mar 31, 2006 | 08:34 PM
Primo131211's Avatar
Exclamation ABS/ASR Problem!!
Hey guys i have a question. I have a 96 z28 and i hit some kind of pot hole. The car hit really hard but was going only about 20. It was night time. I continued to drive and the car started to buck, the abs was messed up. Some warning lights came on "ABS INOP" and "ASR OFF" What happened? how can i fix it? is it gonna be expensive? im so lost. Thanks!
Old Mar 31, 2006 | 09:19 PM
Dave89IROC's Avatar
Re: ABS/ASR Problem!!
something got damaged, you need to get the code/s pulled
Old Mar 31, 2006 | 10:18 PM
what do you think it could be. any idea at all? there is also a rattling coming from the rear. Im gonna be so pissed. I would really be heart broken. this car is my dream. Ill do anything. i have 700, ill throw every penny in. This is my dream car. But if i went and got the codes could you guys help me?
Old Mar 31, 2006 | 11:53 PM
Could be as simple as a loose harness connector on a wheel sensor.... might be worth checking the connections, making sure they are clean and tight.
Old Apr 1, 2006 | 12:46 AM
lgz28's Avatar
abs inop just means that you won't have abs in adverse situations. Probably a wheel sensor or something electrical...if you can't afford the repair just go with the light on...it doesn't affect performance
Old Apr 1, 2006 | 01:17 PM
thanks for the help. Im gonna put the car up on a ramp and take a look. The sensors would just be behind the wheel right? is there a lot i would have to take off? and that rattling could just be the harness too?
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
