about ready to give up
Old Mar 8, 2010 | 12:12 AM
axehead's Avatar
i have read, posted, & searched off & on for quite a while on this.
my headlights suck! at one point i was willing to go HID but that doesn't seem to be worth the $.
why do my headlights not put out good lighting? is it because of the age of my car? its a 93.
i've read where silverstars QC has dropped.
any recommendations?
Old Mar 8, 2010 | 05:12 AM
Have you checked the wiring circuit for the headlights, to insure they are receiving full voltage?
Old Mar 8, 2010 | 08:23 AM
96 Z 28's Avatar
A great suggestion by Injuneer. First step is always to make sure they are working properly.
After that it's on to aftermarket parts or Headlight Bulb Conversion:
DIY Sealed Beam Conversion
or
EuroLights Sealed Beam Conversion
Then you can simply replace the bulb with standard 9006 bulbs or GO HID:
DDM Tuning HID Kits (9006 Bulb)
HID Conversion Pics
Old Mar 8, 2010 | 10:11 AM
axehead's Avatar
no, i haven't checked the voltage. where is the best place to check it & how much is proper.
thx guys
Old Mar 8, 2010 | 10:28 AM
n2ceptor's Avatar
Although its not recommended or legal in most states, you could put 65 watt low beam bulbs from www.rallylights.com , stock is 55 watts..... They are for off road use....
Old Mar 8, 2010 | 06:11 PM
94arcticwhiteM6's Avatar
my assumption would be check across the 2 terminals of the connector and verify you get 12VDC. anything less would show you have a problem and then its time to start hunting.
ChrisFrez
Mar 29, 2015 09:43 PM
armedtrigger
Feb 24, 2015 08:30 PM
CARiD
Jan 27, 2015 06:27 AM
