about ready to give up
i have read, posted, & searched off & on for quite a while on this.
my headlights suck! at one point i was willing to go HID but that doesn't seem to be worth the $. why do my headlights not put out good lighting? is it because of the age of my car? its a 93. i've read where silverstars QC has dropped. any recommendations? |
Have you checked the wiring circuit for the headlights, to insure they are receiving full voltage?
A great suggestion by Injuneer. First step is always to make sure they are working properly.
After that it's on to aftermarket parts or Headlight Bulb Conversion: DIY Sealed Beam Conversion or EuroLights Sealed Beam Conversion Then you can simply replace the bulb with standard 9006 bulbs or GO HID: DDM Tuning HID Kits (9006 Bulb) HID Conversion Pics |
no, i haven't checked the voltage. where is the best place to check it & how much is proper.
thx guys |
Although its not recommended or legal in most states, you could put 65 watt low beam bulbs from www.rallylights.com , stock is 55 watts..... They are for off road use.... :)
my assumption would be check across the 2 terminals of the connector and verify you get 12VDC. anything less would show you have a problem and then its time to start hunting.
