96 LT1 M6 noise / rattle on clutch release and vibration
Old May 18, 2011 | 06:11 PM
Corvette95's Avatar
My 60k mile 96 bucks vibrates and makes metallic noise upon stating off in first gear under light acceleration. It hasd new clutch , pressure plate and throw out bearing less than one thousand miles ago, I thought that was the problem. It also has new FIC fuel injectors, I thought it might be a bad injector causing the bucking. Quick clutch release under heavier throttle everything is good. Noise is annoying under light throttle. I was gonna try a new flywheel but its just a guess. I really am stumped. It runs great, idles great, but slow clutch release rattle and acts like a miss. Any thoughts? no noise in 2 ,3rd or other gears.
Old May 19, 2011 | 04:00 AM
Corvette95's Avatar
Re: 96 LT1 M6 noise / rattle on clutch release and vibration
bump
Old May 19, 2011 | 08:05 AM
rv93's Avatar
sounds like a clutch issue, not engine. it could be warped/cracked flywheel, badly centered clutch, loose just about anything, or maybe even bad quality clutch pads.
Old May 29, 2011 | 07:56 AM
nascarnate326's Avatar
My car had a similar issue and a new flywheel fixed it. Get an iron unit, not aluminum light weight.
Old May 29, 2011 | 08:04 AM
You already posted this on the "Drivetrain" forum, where it belongs. Please do nbot post on multiple forums.
https://www.camaroz28.com/forums/sho...d.php?t=812436
Also, do not "bump" threads or otherwise push them back to the top until 24 hours have passed.
mattszm6
Dec 14, 2014 07:09 AM
jayblev95
Dec 1, 2014 06:55 AM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Christopher
Sep 14, 2002 03:08 AM
