96 LT1 M6 noise / rattle on clutch release and vibration
My 60k mile 96 bucks vibrates and makes metallic noise upon stating off in first gear under light acceleration. It hasd new clutch , pressure plate and throw out bearing less than one thousand miles ago, I thought that was the problem. It also has new FIC fuel injectors, I thought it might be a bad injector causing the bucking. Quick clutch release under heavier throttle everything is good. Noise is annoying under light throttle. I was gonna try a new flywheel but its just a guess. I really am stumped. It runs great, idles great, but slow clutch release rattle and acts like a miss. Any thoughts? no noise in 2 ,3rd or other gears.
Re: 96 LT1 M6 noise / rattle on clutch release and vibration
sounds like a clutch issue, not engine. it could be warped/cracked flywheel, badly centered clutch, loose just about anything, or maybe even bad quality clutch pads.
You already posted this on the "Drivetrain" forum, where it belongs. Please do nbot post on multiple forums.
https://www.camaroz28.com/forums/sho...d.php?t=812436
Also, do not "bump" threads or otherwise push them back to the top until 24 hours have passed.
squarehead
Nov 21, 2014 08:02 PM
