95 Z28 trans lock won't release
Old Mar 29, 2019 | 02:32 PM
Robert Bronner's Avatar
Had put a UMI K member in and a new cam took the whole front end down. Now put it back together and need to move the car. The trans won't shift out of park. Hooked the starter and battery up and still nothing. I know there's a simple answer but just can't think of it. Any help??? Looked on Shoebox site and must be looking past it.
It's an 4L60E btw.
Old Mar 29, 2019 | 03:42 PM
Re: 95 Z28 trans lock won't release
Got it after 4 tries. It just released on the 5th try. Figures right after I make this post. LOL
Old Mar 29, 2019 | 08:33 PM
cardo0's Avatar
Yea I got stuck at PepBoys with the shifter in park. Finally released in front of the service technician while demonstrating It was stuck. I don't know what locks it up but still curious. I don't like doing the panic pull on the shifter just to move the car.
Old Mar 30, 2019 | 11:03 AM
There's a solenoid on the front of the shift lever assembly that prevents shifting out of "PARK" unless the brake pedal is depressed (key must be in "RUN" position). There are several electronic components in the path between both the positive and negative side of the solenoid. There are trouble-shooting tables in the factory manual, for 1995 starting at page 8A-138-0. Free download of factory manuals, courtesy of GaryDoug:
http://www.mediafire.com/?40mfgeoe4ctti
Primary suspect on the positive side is the "Brake Switch Assembly". Could also be the "Ignition Switch" not completing the circuit. On the ground side, the "Transmission Range Switch" is in the circuit, along with an "Isolation Diode". Several connectors, a pass-through and several splices in both side of the circuit. The problem can also be the result of the shifter linkage and shifter cable binding.
U Can't Z Me
Nov 19, 2012 09:48 PM
edman
Aug 24, 2006 07:11 PM
Darklighter
May 27, 2006 07:59 PM
Szizzle
Aug 27, 2005 08:57 AM
Makin' Do
Jan 28, 2003 12:45 PM
