95 z28 anti theft
Old Feb 28, 2014 | 02:59 AM
95z28_396LT-1's Avatar
95 z28 anti theft
i replaced engine with another lt1 from 95 z28 and i have that cars steering column and key and computer so am i gonna have a problem with that anti theft device cause im hearing that i will not get car to run cause of that
Old Feb 28, 2014 | 09:09 AM
Re: 95 z28 anti theft
You don't need the steering column from the other car. Your original key will work fine. The PCM does not care about any key differences-only the VATS module does and you did not change that.
Old Feb 28, 2014 | 09:12 AM
You have to keep your original key (unless by chance it matches the resistance of the new key), which involves changing out the lock cylinder in the column for your original cylinder, allowing you to use the original key. Or you could bypass the security system with a resistor equal in value to your original key.
Just curious... why are you changing out the entire steering column?
Read Shoebox's description of how the security system works:
4th Gen LT1 F-Body Tech-PassKey/VATS
4th Gen LT1 F-body Tech Articles
http://shbox.com/1/vats_bypass.jpg
Old Mar 2, 2014 | 07:27 PM
Fred Holz's Avatar
Talking Re: 95 z28 anti theft
its not real hard to bypass it should you need to.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
97Z28Muscle
Feb 6, 2015 10:44 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
GC456
Aug 8, 2002 11:53 PM
