95 Firebird water pump bolts
Old Oct 2, 2021 | 03:52 PM
Never be fast's Avatar
Anyone know the part number/s for replacement water pump bolts? Currently in the process of replacing the water pump in the wife's 95 firebird with a 3.8L and the bolts need to be replaced.
Old Oct 7, 2021 | 06:50 PM
BandDirector Blk98ZM6's Avatar
Re: 95 Firebird water pump bolts
...don't know the part number, but if you can get one out, even a partial one, take it to Fastenal and they can match it up. I misread the bolt tq numbers when I swapped themostats on my LS1 and snapped a bolt right off! inch lbs is NOT the same as ft lbs. apparently Luckily, there was enough of the bolt left that I was able to back it out with a needle nose vice grip!
gasnmyveins
Apr 21, 2008 11:32 PM
2tight
Mar 3, 2007 07:48 AM
96 trans am
Jan 12, 2006 07:47 AM
Hood_Lum
Dec 30, 2004 08:36 AM
1794Camaro
3rd Gen / L98 Engine Tech
Dec 20, 2002 10:09 AM
