81 Camaro windows
Old Jan 21, 2014 | 08:42 PM
jrj274's Avatar
81 Camaro windows
I am looking to modify my '81 camaro power window system to operate like the newer models. I have always had issues with the windows "dragging" on the rear of the door frame and rubbing on the T-top during opening and closing the doors. The new camaro windows roll down slightly when you open the door and roll up once closed... any one have any ideas...
- Jay
Old Jan 22, 2014 | 11:20 AM
Re: 81 windows
Welcome to CamaroZ28.com!
Not an easy question... I doubt anyone here has done it. But you will have better luck with this posted on the "General 67-02 F-Body Tech" forum rather than in "New Member Intor". I will copy it there for you.
Old Jan 23, 2014 | 07:19 AM
jrj274's Avatar
Re: 81 Camaro windows
Thanks for the advise on what forum to post it to!
Old Jan 23, 2014 | 03:35 PM
As you may have noticed, not a lot of 2nd Gen owners here.
Old Jan 23, 2014 | 11:33 PM
Z28SORR's Avatar
At the very least you wiil need the late model "window control module" and wire it into your car. The problem is, that it is most likely part of the "body control module" for the late model car and that will make the wiring much harder. You should start by getting the wiring diagrams for the late model car and see what is involved.
Old Jan 24, 2014 | 02:43 PM
jrj274's Avatar
Thanks I figured it would be a head ache but worth a shot... i will start with fresh pins and hinges to help the problem in the first place...
capebuf
Jan 13, 2015 07:22 PM
Collector Car
Jan 5, 2015 10:58 AM
rockync7
Jan 1, 2015 05:10 AM
CaRParts102
Dec 6, 2014 08:45 AM
The Seer
Nov 20, 2014 06:32 AM
