1994 z28 not starting
Old May 9, 2011 | 11:07 PM
dumond123's Avatar
Exclamation 1994 z28 not starting
new ditributor new wires new plugs, smells like gas when i try and start it and it turns over, any thoughts?
Old May 9, 2011 | 11:18 PM
94QuasarZ's Avatar
Re: 1994 z28 not starting
Possible fuel pump issue, check your injector fuses as well, what's the story on your ignition coil? Mine was just doing the same thing.
Old May 9, 2011 | 11:59 PM
dumond123's Avatar
ignition coil is good i also replaced that, fuses look good, but havn't checked anything fuel related since i havn't had any problems with it..
Old May 10, 2011 | 12:12 AM
94QuasarZ's Avatar
Does your fuel pump prime normally? Like it doesn't prime slowly/sluggishly?
Old May 10, 2011 | 02:42 AM
dumond123's Avatar
What does "prime" mean?
Old May 10, 2011 | 05:06 AM
Did you just install the (Optispark) distributor? If so, has it never started since you installed it? Is it possible you indexed the splined Opti drive shaft incorrectly to the cam sprocket?
"Prime" means the fuel pump runs for a couple seconds when you turn the key to "run".
Old May 10, 2011 | 12:10 PM
dumond123's Avatar
yeah with 1994 the opti spark spline can only go in one way and i have had it running with it. When i had it running it took a couple turns for the car to start, especially when it was warmed up.
Old May 10, 2011 | 06:15 PM
Originally Posted by dumond123
yeah with 1994 the opti spark spline can only go in one way ...
Actually, about 10% of the people who install the splined shaft manage to get it indexed incorrectly.... much easier to do than it appears.
But if you had it started and running AFTER you did the install, its probably OK.
Describe EXACTLY what happens when you turn the key to the run position. The term "turns over" means different things to different people. Does the starter crank the engine? Does the engine do anything - cough, sputter, backfire - or just "turn over" with no sign of anything firing?
What brand is the new Opti?
Red Hawk 94
Mar 18, 2019 04:03 PM
Noenav
Mar 1, 2019 07:38 AM
cmdeshon
Jan 4, 2015 11:15 AM
thenewkid
Nov 27, 2014 09:41 AM
94z28jbw
Sep 8, 2002 03:22 PM
