Air bag delete.
Old May 9, 2011 | 02:06 PM
LT1 POWR's Avatar
Air bag delete.
Are there any write ups for an air bag delete. So far I've deleted HVAC, ABS, ASR, EGR, and AIR. Just looking to free up some weight and make things simpler. I'd eventually like to incorporate some 5 or 6 point harnesses into a roll cage/bar so I don't think an air bag will do much.
Old May 9, 2011 | 02:59 PM
Guest47904's Avatar
Guest
Re: Air bag delete.
I did it in my 94 when I changed the steering wheel. I pulled out the clock spring and dismantled the air bag from the steering wheel. To keep the PCM from throwing a code, I taped the clock spring to the firing mechanism and connected it to the harness like usual. Put the 2 taped units under the dash and never had a check engine light for 5 years.
I sold the car and told the guy I wanted my steering wheel back, which I did get. He kept the quick release to pull the wheel off.
Old May 10, 2011 | 05:14 AM
Re: Air bag delete.
P L E A S E post on the correct forum. Air bags aren't "engine" tech.
Old May 10, 2011 | 05:53 AM
Chevyssoccer's Avatar
Smile Re: Air bag delete.
that way is no fun, look for the yellow wires and cut them with the ignition on, wait for dust to settle, fix steering wheel...
Old May 10, 2011 | 06:17 PM
Re: Air bag delete.
I don't think the air bag is connected to the PCM. It has its own control module, that turns on the "air bag" light, not the SES.
mike062772
Jun 17, 2015 05:40 PM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
dale3in98
Feb 14, 2015 12:18 PM
Airplanedoc
Feb 1, 2015 07:14 PM
squarehead
Jan 15, 2015 07:02 PM
