1994 Camaro Didn't pass smog.
Old Jan 12, 2013 | 12:26 PM
FiretoFlames's Avatar
I just took my moms 94 Camaro to get smogged and it didn't pass because it failed PCV and Vacuum Lines to Sensors on the visual inspection. Also on the 15mph ASM Emission Test it failed. How can I fix it so I can get it to pass?
The Specs of my moms car are
1994 Camaro 3.4L V6 with 4 Speed auto. also I have to pass smog in California.
Old Jan 12, 2013 | 05:25 PM
GaryDoug's Avatar
Prominent Member
Re: 1994 Camaro Didn't pass smog.
Use this link and download all 3 sections of the 94 service manual. It has many diagrams of the lines.
My Files
Old Jan 12, 2013 | 10:06 PM
What failed.... HC, CO, NOx???? Post the exact results including measured and passing limits.
Old Jan 13, 2013 | 04:04 PM
Here are the results
Old Jan 13, 2013 | 04:41 PM
GaryDoug's Avatar
Prominent Member
From what I understand about this, it means the engine combustion was probably too hot. That could be caused by a vacuum leak. Maybe if you correct the vacuum fittings/hoses that are improper, the high NO may go away.
Old Jan 13, 2013 | 05:03 PM
High NOx is the result of running lean, and/or running hot. It can also result from the EGR system not working. Is one of the vacuum lines that is defective/missing the line to the EGR solenoid, and then to the EGR valve?
The vacuum leak itself could cause it to run lean, but if the O2 sensors are working, they should provide the PCM with a lean reading, causing the PCM to add more fuel.
Scottylt1
Jan 8, 2015 02:48 PM
Scottylt1
Dec 4, 2014 12:31 PM
dreamer1q
Jul 24, 2002 04:39 PM
dreamer1q
Jul 9, 2002 05:37 PM
dreamer1q
Jul 8, 2002 08:47 PM
