Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
z28 running rough
Old May 3, 2010 | 12:47 PM
superlt1man's Avatar
z28 running rough
I have a 94 z28 I replace the opti with a msd unit and added a msd blaster coil and a set of headers. Now it seems as though i lost power. It sounds like one of my cylinders are missing. When the car is running it is shaking and backfiring also. I cant even spin tires. Does any body know what is going on with my car?
Old May 3, 2010 | 01:03 PM
dangalla's Avatar
we gave this guy lots of information regarding a very similar situation, he just did not want to hear what we told him, hopefully this time you listen.. er.. i mean, this is good information. i recommend you listen
https://www.camaroz28.com/forums/sho...d.php?t=750691
Old May 3, 2010 | 05:32 PM
im having that same problem as on that post, thanks for hooking me up with that post. That guy sounded like a a little brat. Can you tell me how to adjust the timing on the opti?
Old May 3, 2010 | 05:35 PM
dangalla's Avatar
after reading your blog post i am going to tell you that it sounds like you have a wire swapped, it is so easy to do and does exactly what you posted, please take the time to go over each and every wire and then come back and we will go from there
one thing at a time, fix the miss first
Old May 3, 2010 | 05:40 PM
ok i live in hawaii and im in the military so i will check it out when i get home from work thanks so much
Old May 4, 2010 | 03:27 AM
thanks man i checked it out and i had 6 and 8 swapped. Swapped them and it runs like a champ. My lt1 is almost stock I put on a 52mm TB , opti, and headers. I would like to swap out the cam what would be a good upgrade for a stock lt1 and where is the best place to get it
Old May 4, 2010 | 08:42 AM
dangalla's Avatar
good, i am glad to hear you got it fixed
cam selection is very important, and there is alot of information already here, you just need to search to find it, what you need to do is do a few searches and do some research on the subject - after that if you still need too, create a thread with lots of information about your car, mods, what you want from the car, things like that,
Old May 5, 2010 | 09:15 AM
bobdec's Avatar
Here's a good a place to start reading http://www.ls1lt1.com/forum/showthread.php?t=25032
Old May 10, 2010 | 02:11 AM
alright, i took it out this weekend and it sounded like it was missing again. I dont know where i should go from here. I rechecked all the wires and everything is on in the right place. it sounds like it is spitting and sputtering. Is their a way to play with the fuel air mixture?
bfmv13trivium
Jan 14, 2015 09:57 AM
1775.Z28
Jan 11, 2015 10:51 AM
Scottylt1
Jan 8, 2015 02:48 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Scottylt1
Dec 4, 2014 12:31 PM
