Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
unstable BLMs
Old May 9, 2007 | 09:00 PM
reamo04's Avatar
unstable BLMs
well, back in march i installed headers and exhaust, and ever since, i have had an annoying backfire at about 2400 or so, it will stumble, then actually back fire
I got tired of just throwing money and parts at it (plug wires, cap/rotor, o2 sensors) and put it on a solus scanner today and drove with it and monitored it as i drove around.
I noticed it was running extremely rich, BLMs would go to about 113 or so, then at idle in closed loop they were 127.
Does this sound like i just need a tune, or does it sound like something with the fuel system or ignition? Would fouled plugs cause this?
Old May 10, 2007 | 05:51 PM
Not sure I understand the sentence above. When are the BLM's 113?
Old May 10, 2007 | 09:35 PM
reamo04's Avatar
sorry, in closed loop, around 2300RPM they were around 113. I have a local guy thats going to tune it for me and try to get it as close as he can
Old May 13, 2007 | 12:50 PM
OBE1 95Z28's Avatar
Verify you don't have any exhaust leaks at the manifold. Usually exhaust manifold bolts need to be retightened after several thermal cycles. Your bolts could be loose after installing your headers allowing exhaust leaks that can throw off your air/fuel ratio.
Old May 13, 2007 | 01:00 PM
reamo04's Avatar
just went to tighten them, i couldnt even get the bolts to budge
Old May 13, 2007 | 06:19 PM
reamo04's Avatar
well, im going to change plugs tomorrow, and than im getting it tuned tomorrow locally, so hopefully one of those two will help
96ZRDR
May 15, 2003 12:05 PM
FireAm94
Apr 25, 2003 12:42 PM
Soma07
Apr 14, 2003 11:36 PM
Dan K
Aug 28, 2002 12:06 AM
