Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Is a smaller aeromotive filter required?
Old Feb 24, 2007 | 03:51 PM
LenT1's Avatar
I have the a1000 fuel pump with the larger 2" fuel filter inline ofcourse.. someone told me I also need the smaller fuel filter (10 micron?) in addition to the larger (100?) micron. What do you guys think.
Old Feb 24, 2007 | 09:09 PM
A 100 micron filter (or as small as 45 microns) is usually used on the suction side to protect the pump, the 10 micron filter on the discharge side to protect the injectors.
Old Feb 24, 2007 | 10:06 PM
LenT1's Avatar
Gotcha. So 100 (or so) between tank and pump then 10 micron between pump and injectors?
Thanks!
Old Feb 26, 2007 | 04:55 PM
Yes. Some pumps, including the Walbro and the Bosch require a 25 micron pre-filter, according to Kinsler. Others, like Weldon require a 45 micron pre-filter. Mechanical pumps will be OK with 100 microns.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
4586
Apr 24, 2015 01:03 PM
Jul 4, 2005 05:00 PM
Wilson
Jul 21, 2002 05:08 PM
