Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Running rough
Old Nov 1, 2007 | 08:42 AM
1997FormulaBird's Avatar
Running rough
My 1997 Formula is loosing power at idle and random times while driving. I will be acceleration lightly and start having random misfires, I know its more than one cylinder because I have no acceleration and tested the temperatures at the headers,
It seems that the whole passenger side is not firing
Like I said it is very random some times it will do it right out of the driveway other time I can drive for a half hour with no problem
I think it is fuel because if you hold open the throttle it will fade and then surge again.
I have a fuel pressure gage that goes inline with the line but cant get the stupid GM quick connect off. How will I know if it is the FPR or the fuel pump depending on the pressure?
Please Help me
Old Nov 1, 2007 | 08:30 PM
V3
The fuel pressure was a constant 40psi and I confirmed that the whole driver side and the first cylinder on the passenger side is not firing. making my LT1 a V3, which sucks
Old Nov 2, 2007 | 07:48 PM
OBE1 95Z28's Avatar
The fuel rail supplies all the cylinders, doesn't sound likely it's a fuel problem if the other three cylinders are fine. Check that you're getting proper firing signal to all the injectors.
Iamherefornow
Jan 26, 2015 04:57 PM
1775.Z28
Jan 11, 2015 10:51 AM
Scottylt1
Jan 8, 2015 02:48 PM
AlaskaZ28
Jan 1, 2015 12:30 PM
Scottylt1
Dec 4, 2014 12:31 PM
