Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Replaced distributor, slightly off??
Old Jul 10, 2015 | 11:52 AM
gonzo275rltw's Avatar
So I replaced the spark plugs, wires, distributor, cap, and rotor on my '87 IROC (305) and I did everything right up until placing the new distributor precisely as the old one. It's the first time I do this on my own, I'm certain the firing order is correct. I called my father who's got more experience and yes, he said that's gotta be the problem. So my question is, how do I fix this? Can I just loosen the hold down bolt on the distributor and turn it slightly until it actually turns on, or have I gone too far in "over complicating" this for myself?
Old Jul 10, 2015 | 12:26 PM
Re: Replaced distributor, slightly off??
Not clear what your father said was the problem? Do you mean he told you that the distributor was installed out of time?
If so, you have to align the rotor to cyl #1 pin on the cap (allowing for the rotation as you insert the helical gears), with the engine approaching #1 TDC on the compression stroke (both valves closed, balancer mark at TDC).
Old Jul 10, 2015 | 02:13 PM
Yeah he basically said that I installed the distributor slightly too far either clockwise or counterclockwise. So I think what I'd have to do is turn in one way or the other until it works? Unless I'm wrong
Old Jul 10, 2015 | 02:34 PM
You may reduce the range of movement available for static advance.
Old Jul 10, 2015 | 06:16 PM
So that can actually work?
Old Jul 11, 2015 | 04:19 AM
So I found the Top Dead Center and got it to run, but it clearly still needs work because it'll kind of "woble" and if stopped for too long (traffic light or stop sign) it stalls out. What could the cause of that be?
REDNECKISBOSS
Mar 22, 2015 08:31 AM
grabbem88
Mar 18, 2015 01:25 PM
brentbrowning01
Dec 3, 2014 10:36 PM
1996LT1Z28
Dec 1, 2014 01:01 AM
ScottZ
Mar 3, 2004 01:34 PM
