Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Which Pump To Use?
Old Jan 20, 2010 | 11:23 PM
Haulinthemail's Avatar
Which Pump To Use?
Hey guys, need a little help. I just dropped the fuel tank and I'm in need of a new fuel pump to support my 383 stroker build. Any ideas on a good setup to run. I currently have stock injectors, TB, and intake, but I will be swapping them out soon. So any reccomendations on systems would be appreciated, thanks in advance.
Old Jan 23, 2010 | 07:19 AM
rskrause's Avatar
Moderator
How much hp do you plan to make?
Rich
Old Jan 23, 2010 | 02:10 PM
koolaid_kid's Avatar
Rich
Excellent question, plus will it be N/A, F/I, nitrous...
All will affect how much fuel you need to supply. You ask about a pump, but then speak of a system. IMHO, system is the correct word, since you must also design the electrical components (wiring, etc.) to handle the mechanical components (pump(s)) you will require.
Old Jan 23, 2010 | 06:20 PM
fuel system
Well I am hoping to be in the mid-500's N/A, I know thats alot to hope for, but I figure aim high. I have the formulas needed to determine injector size, pump capacity, I was just hoping for some good advice on manufacturer, and any tips you guys might have that will make this as painless as possible for me, being a first timer on a build like this its been tough going, but I'm getting there. Thanks in advance guys.
Old Jan 23, 2010 | 11:30 PM
rskrause's Avatar
Moderator
This should do you fine:
http://www.racetronix.biz/itemdesc.a...%2D003&eq=&Tp=
Rich
Old Jan 24, 2010 | 02:21 AM
Yes and no. First, the pump draws more current than the stock pump (+9 amps) so the wiring should support it. The stock harness is marginal for the stock pump, and inadequate for a higher power pump. Racetronix also carries a harness (~$60) that will help in this regard. Secondly, Racetronix recommends that you purchase from one of their vendors. Lonnies Performance sold me mine, and was at the phone when I had issues. Racetronix does not even list a phone number.
Long story short - buy the supporting wiring harness, and buy from a vendor who answers the phone when you have a question.
Also note, at your hp goals, a single pump will be right on the borderline. Any more, and a dual pump system will be required.
Old Jan 24, 2010 | 06:17 AM
rskrause's Avatar
Moderator
Back when mine was "just" 700rwhp I used a single, intank Bosch 255lph pump (same capacity as the Walbro).
Rich
Old Jan 24, 2010 | 09:41 AM
Back when mine was "just" 7000rwhp I used a single, intank Bosch 255lph pump (same capacity as the Walbro).
Rich
Yes and no. The pumps are (incorrectly) rated at 255 lph, b/c that seems to be the sweet spot for marketing. But when they are put to the test, at a given voltage, a given pressure, their mileage will vary.
Personally, I prefer to be on the safe side and have more capacity than the system requires. But that's just me.
Old Jan 24, 2010 | 10:38 AM
rskrause's Avatar
Moderator
I was also using a Kenne Bell "Boost-a-Pump". My preference is for the "just enough" solution as it is usally lighter and cheaper.
Rich
Old Jan 24, 2010 | 07:59 PM
That's a good point. The BAP raises the voltage at the pump, so it spins faster and provides more fuel. Seems kind of expensive, though, when you can put in a second pump for around the same price.
HectorM52
Jul 30, 2017 11:46 AM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
4586
Apr 24, 2015 01:03 PM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
