Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
picīs of Elīmotives crank trigger kits for LT1
Old Jan 10, 2007 | 06:37 PM
jakelund's Avatar
Anyone have that?
I see they sell for ca $160..
Like to know if I can fit this on my turbo LT1 and needs to how the sensor is positioned. (some bracket bolted to the waterpump, I think)
Is it an 8" wheel?
Want to do a crank trigger with wasted spark and Accel gen 7 or Megasquirt.
(perhaps direct-fire if I can fit a cam sensor in my old Opti)
Old Jan 11, 2007 | 08:40 AM
This was the crank wheel and sensor that E'motive included in their original LT1 SDI/Opti-Eliminator kit, back in the late 90's. The sensor is attached under a water pump bolt at about 11 o'clock in the picture:
Old Jan 11, 2007 | 09:50 AM
jakelund's Avatar
looks like the sensor placing is good but the wheel seems to be huge!
Could interfere with my turbo piping i'm afraid..
Thank you for the picture, now I know what it looks like!
/Jake
Old Jan 20, 2007 | 04:15 PM
jakelund's Avatar
If you like to get rid of the distributor (OPTI or conventional) why areīnt more people using this, since this is a angle base timing trigger, wich is superior to a time based trigger like MSD crank trigger? (superior if you have no distributor, angle or time dont matter if you run a distributor)
Even with waste spark it must be better and simplier than flying magnets (MSD) and a distributer, no?
Or isīnt e,motive selling theese no moore? I just saw some speedshop offering this for $160 witch is much less than the MSD..?
I have to make up my mind soon............
Old Jan 31, 2007 | 12:32 AM
WhiteLT1z's Avatar
I'm also interested. I've been looking into doing a MSII setup and use the stock PCM to just run the gauges, hvac, and tranny stuff..
If i do the MSII/EDIS setup, i can completely eleminate the opti right? This seems like a much cheaper option then my ltcc and lt1 edit setup i was going for.
Is there anyone that has a LT1 with MSII w/ the EDIS setup on their car that has any input?
Old Feb 14, 2007 | 03:18 PM
jakelund's Avatar
It canīt be any different then using, for example, a FAST ecm and cranktrigger + camsensor and waste- or direktspark ignition controlled by the FAST ecm.
Well, much cheeper of course
Old Feb 14, 2007 | 03:28 PM
jakelund's Avatar
Iīd rater use the Eīmotive cranktrigger, the megasquirt has support for 60-2 triggers. I think the rpm-limits for edis is around 6500rpm. (the output-power is dropping)
HectorM52
Jun 23, 2016 08:42 PM
oldschool
Feb 9, 2016 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
