Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Fuel Injectors
Old Feb 15, 2007 | 05:02 PM
Red97LT1's Avatar
Fuel Injectors
I finally found out that I have a injector in #7 going bad. The local auto parts store has a replacement for 85.00,but I see that some places sell them as a kit of 8 for around 220.00. What's the difference? Some are high impedance and some are low impendance..What lbs are our injectors anyway? They have from 19-55 lbs. I was thinking that since one is going bad that maybe I should have them all replaced.Thanks
Old Feb 15, 2007 | 05:05 PM
2000GTP's Avatar
The stock injectors are 24#ers. Maybe one of these gentlemen can get you a single injector cheaper:http://shbox.com/1/4th_gen_tech2.html#Dal_and_Jason Otherwise, it is your call if you want to replace them as a set with a good aftermarket alternative such as the Racetronix or Ford SVOs.
Old Feb 15, 2007 | 05:24 PM
Red97LT1's Avatar
The ones I saw were made by Venom.
Are these the ones?
http://www.racetronix.com/621048.html
Old Feb 15, 2007 | 05:29 PM
2000GTP's Avatar
Here is the link, sorry they are Delphi/Lucas injectors sold under the Racetronix name: http://www.racetronix.com/621048.html I don't know anything about the Venom injectors, I see Summit selling them but I have heard no feedback regarding them. Aftermarket injectors such as the Racetronix or Ford SVOs are the popular choices.
Old Feb 15, 2007 | 05:38 PM
Red97LT1's Avatar
So those would be a direct replacement for the factory ones? I can get 8 for around 295.00,which doesn't seem bad to me.
Old Feb 15, 2007 | 05:42 PM
2000GTP's Avatar
Those will bolt right in, you may want to contact them first to see which ones they recommend as they have two different listings for the 24#ers.
Old Feb 15, 2007 | 05:49 PM
Red97LT1's Avatar
Sent them an email.Thanks for the help.
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
