Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Opti Question
Old Sep 27, 2011 | 11:33 PM
Rij1's Avatar
Opti Question
I have a question about what needs to be changed if water or moisture got into my opti. Is the distributor or cap going to have to be changed?
Old Sep 28, 2011 | 07:09 AM
Re: Opti Question
The only thing that could be damaged by moisture is the optical sensor. The rest can be cleaned or dried out. If the optical sensor is damaged, you'll need a new opti. The sensor is not sold separately.
Old Sep 28, 2011 | 06:33 PM
Re: Opti Question
My original Opti was so full of rust at about 50K miles that it clogged the optical LEDs/receptors. The stamped metal "divider" between the cap/rotor and the optical sensor, and the rotating element that the optical wheel and the rotor bolted to were both completely covered with rust. The bearing also appears to be rusting, and very hard to turn.
Sergio
Jan 27, 2016 04:27 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
grgguy
17
Feb 23, 2015 07:57 PM
Injuneer
Dec 15, 2014 09:36 AM
pologreen97z
Dec 2, 2014 10:42 AM
