Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
New problem... Ignition fuse keeps blowing
Old Nov 20, 2008 | 02:03 PM
1QuICkA$$z28's Avatar
A have a problem, i have a 1995 z28 thats basically stock. The ignition fuse thats under the hood keeps blowing out i think its number 7. As soon as i turn on the car it blows. I went through like ten fuses and realized that something is wrong, could it be a short somewhere? Where do i start looking?
Old Nov 20, 2008 | 10:46 PM
Anything that causes excessive current draw, including a short will cause the fuse to blow. Look in your Owner's Manual to see a list of the devices on that particular fuse. Then check the wiring to each of those devices.
Old Nov 22, 2008 | 11:24 PM
Fatdog2's Avatar
Aftermarket alarms can cause some issues.Try disconnecting it and see if that helps.(even if the fuses look good to the eye,they can be toast.My02.
Aug 18, 2015 07:08 AM
malikot02SS
Aug 15, 2015 01:11 PM
350350
14
Aug 11, 2015 12:03 PM
96SilverRam
Aug 9, 2015 04:15 PM
RUNMYTA
Jul 15, 2015 07:50 PM
