Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
need help A.S.A.P.
Old Oct 16, 2011 | 12:22 PM
bigwalk's Avatar
need help A.S.A.P.
New motor in 97 camaro I have all my connection's made that I can tell. When I go to turn the ignition on nothing happen's. I put a test light on the battery post, and I'm getting fire there all the way down to the starter. After that nothing at all, I'm starting go get frustrated with the darn thing can someone please give me a little advice please. This is my first efi car that I'm trying to mess with ever don't want it to be my last, so please give me a little advice.
Old Oct 16, 2011 | 01:29 PM
MyFastTA's Avatar
Re: need help A.S.A.P.
You need to verify that the starter is getting its B+ (constant battery voltage) on the large guage wire at the starter. Then while having someone attempting to crank verify you have battery voltage on the S terminal or small wire. If you have both of those then the starter is bad if you dont then you have a connection or control issue.
Old Oct 16, 2011 | 01:58 PM
DirtyDaveW's Avatar
Just to be clear, are you saying you have everything hooked up but when you turn the key to start, you hear nothing? No clicks, no cranking, just silence?
It could be one of several things;
  • Bad starter
  • Bad ignition cylinder
  • Bad ignition switch (under the dash on top of the steering column)
  • Wire(s) on starter not attached correctly/firmly.
  • Neutral safety switch not hooked up or bad
Old Oct 16, 2011 | 09:29 PM
bigwalk's Avatar
I got it fixed the hot wire that run's from the positive side of the battery to the distribution block was missing. How many big hot wire's does your car have going to the starter.
Old Oct 16, 2011 | 09:58 PM
DarkKnight
Oct 5, 2010 05:35 PM
mrbadlt1
Jun 22, 2010 01:04 PM
quiklt1
Jun 15, 2010 09:12 PM
ninetyfourZ28
Parts Wanted
Apr 13, 2009 06:45 PM
thzzz28man
Sep 7, 2003 11:41 AM
