Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
need help finding where a vac line goes...
Old Jan 22, 2007 | 08:22 PM
brucetrentcamaro212's Avatar
I did some repairs myself and forgot where a vac line goes.
I dont know what its called But I can describe where its located at. I hope you guys can help... As you look at the front of the motor,to the left side next to the valve cover and the intake there is a plastic piece that slides up and down and has two vac hoses on it one I think goes to the throttle body and the other is the one that I dont know where it goes from there. It looks like it would travel under the front of the throttle bodyand goes to the drivers side some where but thats as far as I know
also if anyone has a good tip on removing water from a gas tank. I got some bad gas and I put heet in the tank but I was told that the water will sit at the bottom of the tank and it will take a while to remove it. Thanks for the help
96 Z28 camaro...
Old Jan 22, 2007 | 10:57 PM
Sounds like the EVAP canister purge line. Shoebox has a diagram of that system for the 96/97 models. Line #2 in the diagram is the 3rd line in the fuel line bundle:
Old Jan 23, 2007 | 09:24 AM
Thats the line I need to know about. But on my 96 I dont see that line 2 that it goes into anywhere . I have had this motor put in by a guy that I dont think he put it together right. anybody have any other ideas. thanks for the post, I will keep looking for it
Old Jan 23, 2007 | 09:33 AM
OBE1 95Z28's Avatar
Line 2 hooks to the purge solenoid (11) and the line returning to the canister that's buried in the fuel line loom tubing (3 lines head to the back of the car, fuel feed, fuel return, and canister).
Old Jan 23, 2007 | 08:59 PM
One more thing here, My number 11 on the diagram has 2 vac lines not just one. does any of you guys have that on yours. its the bottom line that I cant find where it goes. I appriciate all the post thanks guys..
Old Jan 23, 2007 | 10:09 PM
Are you referring to item #15? See in the diagram where it says it is a vent and there is no connection?
Actually, there are 3 connections to #11. One in, one out and the vent.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
squarehead
Nov 21, 2014 08:02 PM
