Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
intermitent no spark at coil wire
Old Jan 24, 2007 | 02:06 PM
barr747's Avatar
1994 z28.engine dies,will restart after sitting 10 minutes.No spark at coil wire .ignition module and coil replaced.Would bad optispark unit cause no spark at coil wire,
Old Jan 24, 2007 | 02:24 PM
2000GTP's Avatar
It could be the optispark, but then again it could also be the optispark harness, the PCM, or any wiring in between. I would check all the harnesses and connectors for starters and make sure you have good connections. Poor connections can easily lead to intermitent problems.
Old Jan 24, 2007 | 02:38 PM
OBE1 95Z28's Avatar
Troubleshooting guide from Shoebox's site: http://shbox.com/1/4th_gen_tech2.html#opti_test
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
greenzee28
Mar 26, 2015 09:13 AM
sleeperZ96BT
Jun 5, 2005 09:33 PM
DougJ
Aug 29, 2002 12:51 AM
