Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Mounting an external fuel pump help?
Old Oct 3, 2010 | 09:50 AM
  #31
sscott's Avatar
Originally Posted by Injuneer
Did you use Shoebox's guide to check the fuel level issues?
http://shbox.com/1/4th_gen_tech2.html#fuel_gauge
The -10AN (5/8") suction line for my outboard pump comes off a connection at the bottom/back of the tank. There's a baffle and a screen inside the tank. The stock fuel line coming out of the tank support assembly is only 3/8". I also have another aftermarket pump in the tank, in the stock location/stock bracket. The outboard pump only runs when the nitrous system is armed.
http://www.injuneer.com/images/photo.../DCP03576a.jpg
You don't need a $500 stock fuel pump. You don't need a $250 pump with a bucket. You can get a Racetronix 255 LPH pump that fits in the stock bucket for $150.
Don't you have to modify the stock bucket for the 255 to work properly? I heard you have to modify the stock bucket.
Old Oct 3, 2010 | 04:46 PM
  #32
The glue for the bucket comes with the Racetronix kit.
http://www.racetronix.biz/customkiti...RFPK%2D003&eq=
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
