Miss Fire On my Truck Need Help.. thanks
I come here for all my camaro help now I need some help on my 2000 silverado 5.3L thing is acting hella weird... here is what it is doing...
Miss Firing.. but here is the catch it dont do it all the time, miss fires at cold start, has done it at operating temp as well, but It has went weeks with out doing it then weeks doing it I am been dealing with this since around x mas time... I do get a check engine light that comes and goes.. have had it scanned and have had 3 different miss fire codes... including multi miss fire code, and number 2 and number 7 miss fire as well at two different times... number two has came up several times...
Here is what I have done... new plugs ( OEM replacement at $7 each plug) MSD plug wires... coil number 2 replaced ( was first code I got and changed it) after none of that fixing it I have replaced fuel filter and ran a fuel system cleaner including a water remover ( hear 5.3 are known for getting moisture in fuel system) after none of this not working I am stuck... Just put like a 1/4 tank of race fuel in it see if that would help clean it out...
any ideas what it could be??
Re: Miss Fire On my Truck Need Help.. thanks
Its funny you say that I been starting to think about my fuel pump.. I will have to check out my fuel pressure.. and these chevy's are known for having fuel pumps go out but this is the second one I had to put on.. the last one just went out wouldnt run.. Ill have to check that out thanks for the input
Checked the regulator pressure it is good, as well as checked the vacuum lines for gas all clear.. seems as the regulator is working correctly.... damn i hate to tear it down seems like I might have a bad valve spring or stock valve or something... I swear when I get alittle money saved for my camaro project something always comes up!!!!
ducttape1975
Jul 10, 2015 06:29 PM
Jul 10, 2015 02:23 PM
