ignition fuse problems
i recently hooked up a subwoofer that draws 12v directly from the battery. the 12v cable has a 30amp fuse right near the start of the cable near the battery. When i first put a fuse into the amp, i started my car and it immediately died after about 3 seconds of putting it into gear. When i found out the problem was my ignition fuse, I replaced it and turned the car on again. I made it about 30 feet when the fuse blew again. Ive been through about 5 fuses so far and it keeps blowing. What ive discovered is that when i take the fuse out of the subwoofer cable, i stop blowing my ignition fuse. What could be causing this?
eanhl2004
Apr 4, 2015 12:01 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
