Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
how many guys here running e85
Old Nov 2, 2007 | 07:19 AM
transam001's Avatar
i was just woundering how many people are running e85 in there cars.. what did you have to change besides injector and fuel pump.. thanks for the help...
Old Nov 2, 2007 | 11:06 AM
White Lightning's Avatar
im curious as well
Old Nov 12, 2007 | 07:20 PM
96ZCamaro's Avatar
What does it take to run e85 anyways?
Old Nov 12, 2007 | 08:50 PM
93transam1234's Avatar
i have seen one f-body with e85, dont remember if it was here
Old Nov 13, 2007 | 05:08 AM
rskrause's Avatar
Moderator
I am not running it but have learned a bit about it and am familiar with using methanol in race cars, which has many of the same issues. E85 requires ~50% more fuel volume to achieve an equivalent mixture. The main thing required is therefore upgrades to the fuel system to deliver ~50% more fuel. A stock fuel pump may be capable - depends what you are starting with. Larger injectors will certainly be needed as well as reprogramming of the ECU.
If an equavlent mixture is used, the extra fuel volume needed will translate into an ~50% decrease in fuel mileage/gallon. Your tank will seem a lot smaller! Most cars built in the late 90's or later should have materials compatible with E85, but this may be a problem on some and will be a problem on older cars in all likelihood. New vehicles will not have a problem.
Richard
Old Nov 18, 2007 | 03:03 PM
reamo04's Avatar
http://www.theturboforums.com/smf/in...?topic=47094.0
that link will GREATLY help.
My new build will be e85 based
Old Nov 18, 2007 | 03:19 PM
rskrause's Avatar
Moderator
Why? And what are you planning regarding the fuel system? Where do you live? I assume you can get it at the pump?
Richard
Old Nov 18, 2007 | 10:20 PM
reamo04's Avatar
Richard
yes, theres probably 3 stations ehre in town that have e85.
Right now, either an aeromotive ae1000, and some 96# injectors, or 2 255lph pumps and 96# injectors.
I live in kansas, and the closest station to me is about 7 minutes from me to get e85
oh, and i am using it, due to it having a little bit colder charge
Old Nov 19, 2007 | 05:12 AM
rskrause's Avatar
Moderator
Sounds like it will work well for you. Once you make the change, I'd be interested in knowing the results. Especially dynio numbers +/or track times and fuel economy. How do you plan to tune?
Rich
Old Nov 19, 2007 | 04:33 PM
reamo04's Avatar
Rich
either doing tunercat, or making the switch to megasquirt, not sure which one quite yet
Old Apr 10, 2008 | 07:41 PM
flyinZ's Avatar
Any update on this topic?
Old Apr 10, 2008 | 11:09 PM
chads97z's Avatar
im running E-85
got a Alchy compatable Berry Grant fuel pump, BG fuel filter that get changed every 2 months
ford SVO injectors w/ teflon o-rings and Accel adjustable fuel regulator
rest of fuel system is stock
another thread on this board has my before and after HP/TQ from 91 to E-85
i also live 2 miles from the only station in San Diego that sells E85
Old Jun 24, 2008 | 09:23 AM
Z-e85's Avatar
I have been running it for 4,000 miles. I put up a web site with pics and some information. Will update page every 3,000 miles. http://www.z-e85.com
Only a $500 converter is required. An additional $200 for 8 pulse plugs that will replace spark plugs are supposed to increase fuel efficiency 5-7%. Will probably replace my platinum plugs at the end of the summer.
94Z28LS1toLT1
Jan 15, 2015 07:18 PM
1775.Z28
Jan 11, 2015 10:51 AM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
cmdeshon
Dec 27, 2014 10:06 AM
Red97LT1
Aug 7, 2002 05:45 PM
