Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Im getting bad gas mileage....need help figuring out the cause
Old Jun 24, 2008 | 02:50 PM
jeffcamaro2007's Avatar
i had the fuel pump go out awhile ago and on that tank of gas its gotten worse ever since. Im gonna do a tune up with new plugs and wires but im afraid of ruining the new plugs if im running rich. thinking it might be the o2 sensors and i might replace those too. but im not throwing any codes for them.
My question is how can i tell if im running rich and/or wats causing the bad mpgs?
I also am running an open y pipe....dunno if that matters at all but just throwin it in there.
Old Jun 24, 2008 | 02:53 PM
the old plugs how do they look? looks like they might have some oil on the threads and the tips are fairly black. they are bosch platinums btw. can you tell by this if im running rich.
Old Jun 24, 2008 | 03:06 PM
i was getting 200 on a tank before. it went to 180 or so on the tank the fuel pump went out on. now its like 165-170. my driving habits havnt really changed. ive been driving more lately but not up hills or in alot of traffic. i usually try to shift at around 2k sometimes a little more. my driving is also 100% city.
I know those numbers are extremely low but its because my spedo reads about 10mph slower than im actually going.
check out the pics of the old plug i posted.
Old Jun 24, 2008 | 05:46 PM
could it be that i just need a new fuel pressure regulator?
Old Jun 24, 2008 | 07:31 PM
roguedriver's Avatar
The Y pipe could cause issues depending on how close it is to your O2 sensor. If its close, it could cause it to read lean, therefore inducing the pcm to add more fuel to compensate. I'd close that sucker up, put in new plugs, and re-test it.
Ken R.
Old Jun 24, 2008 | 09:09 PM
omfg how the hell do you get the #8 plug out?!?! Im burned, bleeding, eatin alive by bugs, dirty and soar. Im using a universal joint and i finally got the damn thing on but i cant turn it with the 2 inches of room i have and 1 finger. ****!
any ideas?
warmeck
Mar 22, 2015 06:43 PM
Deadbolt24
Jan 19, 2015 01:29 PM
smokin25th
Jan 1, 2015 09:06 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
simple
Aug 11, 2002 11:56 AM
