Fuel and Ignition Fuel Pumps and Systems, Ignition and Spark Systems
Hot Start Slow Crank [solved]
Old Dec 20, 2021 | 10:10 PM
1994-LT1-Eric's Avatar
Hi,
I just wanted to share that a new starter fixed my hot start problem. I suspected the ICM, or ignition coil and replaced both, assuming they were old and heat soaked from the driver side head, even after the ICM mod.
Wasn't the case. The starter had been on there since 2002, was weak and didn't seem to have the volts/current to crank properly when hot, and the start cycle behaved like a drained battery.
In case anyone else runs into similar symptoms check the starter. I swapped ICM and coil because it was easy and pretty cheap, but ended up not being the culprit. Cleaned up wire terminals, R&R'd the starter and it's good to go. Even cold starts sound healthier now.
1994 Z28 1LE M6
127K mi
SPEC Stage 2+ clutch
Borla catback
Old Dec 21, 2021 | 08:54 AM
Re: Hot Start Slow Crank [solved]
Thanks for following up. Wish everyone would do this.
Old Dec 21, 2021 | 06:17 PM
This is the one I purchased. Had good reviews and is working fine thus far:
1994 Z28 Starter 1994 Z28 Starter
Old Dec 26, 2021 | 12:00 AM
JakeRobb's Avatar
Super Moderator
If you hear a stampede, think horses, not zebras.
In other words: a starting issue resolved by replacing the starter? You don’t say!
I kid. But also, yeah — don’t skip the obvious stuff!
Old Dec 27, 2021 | 08:26 PM
True 😄 it was the hot start barely turning over that had me thinking ICM or IC. Now I've got a couple used spares. That bracket assembly with the ICM mod and thermal paste needed cleaning and new paste anyway 😅
finn
May 26, 2005 02:39 PM
Castro
3rd Gen / L98 Engine Tech
Aug 27, 2004 12:45 PM
jeeves_83
Aug 2, 2004 08:49 PM
jcurrieirocz
9
Jul 4, 2004 05:47 PM
craigmaro
Jan 28, 2003 12:37 PM
