Car Hot = Starter Don't Turn So Good
Old May 26, 2005 | 02:18 PM
finn's Avatar
When everything is cold, the car fires up flawlessly. When I try to start it after it's been warmed up, the starter seems like it doesn't want to crank. The battery is new and fully charged.
Is this a symptom of a bad starter? Any tests I can run on it?
Thanks,
Finn
Old May 26, 2005 | 02:21 PM
OBE1 95Z28's Avatar
Re: Car Hot = Starter Don't Turn So Good
Does it make a chirping noise? When I went to an aluminum flywheel, might would make a chirping noise on a hot start. I cured thsi by shimming the starter away from the block.
Old May 26, 2005 | 02:26 PM
finn's Avatar
No chirping noise, just a RRRRRrrrrrrRRRRRRrrrrrrRRRRRR, like when your battery is low. Maybe when it's hot it's drawing high amps -- could that be a sign that the starter is bad?
Old May 26, 2005 | 02:36 PM
LT1Squirrel's Avatar
heat is a big culprit in making a starting not start so well, try to fab up a heat shield around the starter and youll rid yourself of the hot start problem
Old May 26, 2005 | 02:39 PM
OBE1 95Z28's Avatar
No need for a heat shield if you're not running LT headers. Sounds like it's time for a new starter.
bernie1951
Dec 10, 2014 10:03 AM
A's 91 Z28
Dec 7, 2014 12:09 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
Dave19yz28
Jan 26, 2003 01:45 PM
